Chieftain track
John chamney
Has liked: 5 times
Been liked: 2 times
Chieftain track
Post by John chamney »
Hi all
Bit of advice please , just received chieftain no 42 :D which is my first ever armortek kit ! Question is should the tracks be painted ? Cheers
Has liked: 1040 times
Re: Chieftain track
John, welcome to this great community. You’ll find all the help you need here. May I suggest you read through the Basic Topics on the Knowledge Base? You’ll find most of the answers you need there. And the answer to your question is: you don’t need to but the Chieftain steel tracks would benefit from etch priming and some colour and weathering. The latter is a matter of personal taste.enjoy your model - it’s addictive. Stephen.
John chamney
Has liked: 5 times
Been liked: 2 times
Re: Chieftain track
Hi Stephen
Thanks for the prompt reply , just finding my way around this site , have to say am well impressed with the build quality and commitment to detail , being a newby to the community hope I can get somewhere close , cheers .
John
Richard Goodwin
Has liked: 294 times
Been liked: 291 times
Re: Chieftain track
Post by Richard Goodwin »
Hi John,
As Stephen says, painting tracks is a personal preference. I’m painting mine individually, not sure if the paint will stay on, only time will tell but it sure looks good at the moment.
John chamney
Has liked: 5 times
Been liked: 2 times
Re: Chieftain track
Thanks Richard for the reply , will definitely paint . Already hit a stumbling block two number hull brackets,A ES0106 are missing so can’t build the hull :( .
Regards John
Richard Goodwin
Re: Chieftain track
John, If you look at my blog 'A Chequered Chieftain at #10', you'll see what I did. Am not saying its correct but it may give a few idea's on how to approach it. Would highly recommend doing a full parts check if you haven't already; even with best intentions, these things can and do happen. If you contact Armortek via email, I'm sure they will send out replacement parts.
