Hi,
A few pics of my Sherman originally built by Chris Fry and it's as good today as it was when he sold it seven years ago...great job Chris
Sherman
- Has liked: 158 times
- Been liked: 688 times
- Has liked: 224 times
- Been liked: 181 times
Re: Sherman
WOW David! That looks GREAT! There's sure been a LOT of detail work put in it!!
How do those 'Duckbills' on the tracks hold up? I've been curious about'em but don't know how sturdy they'd be.
Mike
Mike
Re: Sherman
Hi,
I've had no issues with the duckbills and would recommend fitting a set. They can become bent up if driving over obstacles but easily manipulated back into original position.
- Been liked: 48 times
Re: Sherman
Chris got the duckbills from me years ago. They were made from sheet metal and represent the slip on pattern and are held in place with the tooth connecting bolt which needs to be drilled by the user. I always wondered how they would hold up with use since I never designed or used them on an RC tank.
And true to form the slip on types did bend very easily and were much weaker than the cast pattern duckbill
They are still listed on the catalog but are a real pain to fabricate. I was thinking about removing them due to the hassle of fabrication, or possibly material swapping them for printed units. The white material might be able to hold up but I would need to do some R&D before hand
