Helicoils
Simon Peck
Has liked: 7 times
Been liked: 46 times
Helicoils
Post by Simon Peck »
Dear All,
I need to replace some of the helicoils in my suspension bars. Can you advise which make, type and size I need so as I can order the correct tools?
yves mouton
Been liked: 741 times
Re: Helicoils
Post by yves mouton »
Hello Simon,
I also did replace some helicoils for my tiger 1.
I have a set from the brand Phantom size 1,5-D M6-1,0
If you buy a set the tools to place the coils are included.
I will post a picture later in the afternoon.
Best regards Yves
yves mouton
Re: Helicoils
Hello Simon,
Here is the picture of the Phantom set coils.
Best regards Yves
David Skeldon
Has liked: 33 times
Been liked: 312 times
Re: Helicoils
Post by David Skeldon »
Hi.
Never liked helicoils. Always found Time inserts by Width much better.
Simon Peck
Has liked: 7 times
Re: Helicoils
Hi Yves,
Thanks for the reply. Did the Phantom helicoils fit without having to re-tap the existing holes? Do you have a source for them as I couldn't find after a quick search.
Kind regards,
Simon
yves mouton
Re: Helicoils
Hello Simon,
You can take out the helicoil with a narrow pliers,
and if necessary you can re-dril the hole, but normaly if you can take out the helicoil
you dont need to re-drill.
The Phantom set i bought in my country: Belgium and the company name is Tollenaere.
Best regards Yves
