Elefant Gun Controls
Posted: Wed Dec 12, 2018 6:55 am
by Ray Brown
G'day Guys,
I'm using a spektrum 11x transmitter with mode 2. The throttle & rudder stick are L/R, up and down repectively. My issue is the spring loaded rudder stick which causes the gun to return to centre when the rudder stick is released to centre. I want the gun to stay at the intended position reached when rudder stick released. Do I need to change Tx settings? Hope this makes sense.
Ray
Re: Elefant Gun Controls
Posted: Wed Dec 12, 2018 10:46 am
by Stephen White
Ray, sounds like there is some basic setting up to do. The XG-11 transmitter is not familiar but the stuff below should be generic for most Spektrum transmitters.
Firstly, you might check your basic radio setup to assign channels to the four sticks (and set the fail-safe). The Knowledge Base guide is here:
http://www.armortek.co.uk/Forum3b/viewt ... 4330d04da9
You should end up with controlling your tracks (steering + fwd/reverse) on the right stick, with elevation and traverse on the left.
Mode 2 transmitters are set up with spring centering on both axes on the right stick and left/right on the left stick. The left stick up/down should have a ratcheted, non-centering stick. If you assign elevation to the left stick, you should be set. If the rachet is on the right stick (ie Mode 1), you'll need to get into the back of the transmitter and make some physical changes to change to Mode 2 ie to swop the rachet from right to left.
It's quite simple to do but rather than go through it here, I'd suggest you look at one of the excellent YouTube videos available. There's one from down your way here:
Hope that helps.
Posted: Wed Dec 12, 2018 11:05 am
by Armortek
Ray, Stephen has nailed this on the head.
To get the servos to stay in the desired position you will need to change the mechanism in the transmitter.
Kian
Posted: Thu Dec 13, 2018 10:28 am
by Ray Brown
You should end up with controlling your tracks (steering + fwd/reverse) on the right stick, with elevation and traverse on the left. CORRECT
Mode 2 transmitters are set up with spring centering on both axes on the right stick and left/right on the left stick. The left stick up/down should have a ratcheted, non-centering stick.CORRECT If you assign elevation to the left stick, you should be set. If the rachet is on the right stick (ie Mode 1) MINE IS MODE 2, you'll need to get into the back of the transmitter and make some physical changes to change to Mode 2 ie to swop the rachet from right to left.
Hope that helps.
My issue is the traverse left and right using left stick which is spring centering causes the gun to self center upon release. So you can't traverse right and leave gun over machine gunners hatch for example.
Ray
Posted: Thu Dec 13, 2018 11:44 am
by Gerhard Michel
Thre is also another way using a servo to control elevation and yet getting a behaviour that is independent of the stick position.
Each servo consists of three main parts, the motor-gear unit, an ESC unit and a potentiometer (pot) giving the actual position of the servo arm to the ESC for correction. If you simply remove the pot mechanically, but let it be wired and take it to its middle position, then you get a drive unit for gun elevation, which works independent of the static stick position; only controlled by the time the stick is out of its middle position! E.g. if you put your stick forward or backwards, the gun is moving down or up (with variable speed depending on actual stick position). If the stick is centered again then the gun stops at the current position.
Please note: if the servo has a mechanical stop at each end of its way, this stop should be removed to avoid damages when running against these stops!
I use a transmitter with all sticks centered by springs (also driving control). So I have free choice to use my sticks for the various controls. Influenced by my airplanes I use the left stick for driving and moving the turret and the right stick for gun elevation and steering the tank (mode 4).
Posted: Thu Dec 13, 2018 9:37 pm
by Shaun Hunt
Hi Ray,
I'm not familiar with your radio I use Futaba myself, my explanation below can be set up on my Futaba transmitter.
Thinking outside the box, you may be able to set the trim for your gun traverse channel to 100% rate giving you 100% servo travel using the trim control.
I would also set the travel limit for the gun traverse channel to 100% as well to prevent over driving the servo.
This would give you fine positional control of the gun traverse with the trim control, also proportional control with the traverse stick which would return to the trim setting when centred . Gun traverse with the trim control would be slow but realistic.
Hope you can understand what I'm trying to say
Regards Shaun
