Hi all
Wondered if a sort of proportional smoke effect could be accomplished by wiring my 24v smoke fan to the motors - one at each motor power cables
The heat element is still wired to a on-off switch remotely controlled via my transmitter
Any thoughts here
proportional smoke
- Steen Vøler
- Has liked: 62 times
- Been liked: 500 times
- Has liked: 1475 times
- Been liked: 1674 times
Re: proportional smoke
Steen, I thought you already had one of my smoker fan control units ?
There are a couple of problems when using the motor supplies.
1) Possible damage to the fan when running the tank backwards, as the voltage across the fan is reversed. You need a bridge rectifier to solve this.
2) There's no smoke output when the tank is not moving. There's no solution so this, other than using the smoker output from the Benedini board, as I do with my module.
If you want to stick to pure analogue (I've got massive overkill solution with a raspberry pi) you would use a rectifier (as Adrian suggested) from the motors AND a drip feed from the main supply (resistor and diode) for idle.
- Steen Vøler
thanks Adrian and Sam
@Adrian - i did have one unit, but it was installed in my JP which is now sold
cheers
Steen
Steen
In that case it sounds like you need another one
- Steen Vøler
do you still have one?
My new setup is Benedini Mini with 60 w amplifier.
Smoker is pure 24v, both fan and heat element
cheers
Steen
cheers
Steen
cheers
Steen
Steen
I always keep a stock
Price is still 49ukp + P&P and paypal fees.
Email me at sales@armortekaddict.co.uk for a complete cost to Denmark.
