Tiger 1 - 2003 - Track maintenence
Posted: Mon Jul 02, 2018 12:10 pm
by Steen Vøler
Hi all
after a year of running the Tiger in various terrain, it was time for track inspection. What startet out as a routine job turned out to be a little more than that.
On the left side, 12 track pins was loose - they had lost their push lock washer. I had only 5 of the new type with pin lock so I had to reuse old track pins.
I used a 1mm metal drill and started using a punch tool to mark the drill hole and then gently bore the hole for the pins. All went well and I now have extra spares.
Also painted the turret number 213 and the Tiger is now ready to go on tank show Saturday in Sweden
Re: Tiger 1 - 2003 - Track maintenence
Posted: Mon Jul 02, 2018 3:01 pm
by Sam Hough
Excellent I'm running out of the starlock fasteners. Do you get the new style ones from Armortek?
Turret looks fantastic. Lot of work yet to do on ours.
Posted: Mon Jul 02, 2018 4:06 pm
by Steen Vøler
Hi Sam
The new pins are from Armortek - I had som spares from an earlier tiger build that I reused. Armortek do sell the new pins so no problem for you to write to them :-)
Thanks for the comment on the turret :D Its nice when everything just do succed :D
