Rear Axle
Posted: Sat May 26, 2018 3:41 pm
well gents i have been following several build threads.
My queries at the moment concern the assembly of the axle.
I get the point of Loctite a 3*14 pin into the EP0205.
this sub assembly then fits into the slot of the differential (CP0279)
my concern is that its not a very easy fit- the pin is too fat or the slot needs fettling- so i can slide it in.
How far should it go in as well?
Any thoughts on the matter.
thankfully i noted the comment about diagram 8B otherwise i would have not put the shaft to connect to the bevel gear
before using loctite to fix EP0202 in place
