Bump stops
Greg Stephens
Been liked: 11 times
Bump stops
Post by Greg Stephens »
Does any one have measurements for the Tiger I bump stops? I am going to try to make a set from scratch. It looks like the main body is the same height as the kit supplied set.
I am using the cad file from Tiger Info as a model.
Has liked: 794 times
Re: Bump stops
Greg, I have made my bump stops using the dimensions from that .dxf file and dividing them by 6 to make it 1/6 scale. I could make you some 2D drawings with all the dimensions or I can use the original .dxf file and give you the original dimensions.
Greg Stephens
Re: Bump stops
That is what I figured everyone was doing. When I used the measurement tools on the autodesk viewer I got ridiculous numbers. The height of the main body shows as 414.8mm. The Armortek bumpstop is 28mm high.
Let me try again.
Sadly, when I graduated college from an Industrial Arts program.we were still using drafting boards. Autocad was just coming out. I probably need to actually learn it.
