25 pounder tooling mark's
andyquirot
Been liked: 33 times
Post by andyquirot »
Hi all
I have just opened my birthday present and found a 25pounder .😀
Question do I need to remove the tooling mark's before I start building. As I don't want to build and Paint then to find I can see the tooling mark's.
Regards Andy quirot
Robert Reid
Has liked: 99 times
Been liked: 446 times
Re: 25 pounder tooling mark's
Post by Robert Reid »
Flat plate and 400 grit removes most tooling marks.
If you don't have a flat plate, a piece of glass works great!
Of course, the originals had a lot of tooling marks, casting slag, roughness from foundries, etc. War Finish was a genuine 'mark' on British products to designate the fact that they did not fettle to the pre-war degree of perfection. So a few tooling marks may well be in keeping with the original.
RPR
andyquirot
Thanks.
I had not thought about tooling mark's on the original. I may need to do more research.
Regards Andy
Has liked: 1495 times
Been liked: 1699 times
The problem is you have 1:1 tooling marks on a 1:6 model.
Dave Dibb (Armorpax)
Has liked: 116 times
Been liked: 1106 times
Which can be modified with a bit of Mr Surfacer 500 and an old brush :-)
Tooling marks etc are also one of the reasons hand made imperfect parts look better than 3D printed perfection when representing wartime models etc!
Dave
www.armorpax.net
andyquirot
Hi there
Mr Surfacer 500 is this the same .
Mr. Hobby #SF-285 Mr. Surfacer 500 (40ml) Gunze surface primer
Bidding number 371110600249
Regards Andy Q
Yes :D
andyquirot
Hi All
Is the normal on a new kit.
I am worried about cleaning it and it coming back later in life.
Regards Andy Q
Hi Andy,
I have had it on many of the sheet parts, its only very light surface rust. I normally just give them a rub down with a sanding block and prime, so far had no long term issue with my 25 Pdr. On the Pheasant they were the same and I have just polished the worst of it off and sealed them for now as planning on leaving it in metal until after the summer shows.
A week at War and Peace and anything I have missed looks much worse :-)
Dave
www.armorpax.net
andyquirot
Thanks Dave
Also the parts arrived today thanks.
Regards Andy Q
Kevin Hunter
Has liked: 605 times
Been liked: 147 times
Post by Kevin Hunter »
Hi Andy, regards from the other (better 😀) Island.
A bit of rust is pretty common on sheet steel parts, especially in our high salt environment. As has been said, it’s usually just on the surface and will clean off easily. If you are concerned about heavier rust a dab or two of “rust eater” fluid from your local motor accessories shop will give added peace of mind. Once cleaned up, get a coat of etch primer on and some paint, all will be well.
Kevin
andyquirot
Hi Kevin
I have cleaned the parts and put etch primer on this morning. Nice to know somebody else in the channel islands builds Armortek stuff what do you have?.
Regards Andy Q
Kevin Hunter
Sorry Andy. Not ignoring you just been busy with work.
I’ll reply properly off the air so to speak.
Kevin
