Page 1 of 2
Water slide decals
Posted: Fri Oct 27, 2017 9:05 pm
by Paul Wills
Hi All,
Can anyone point me in the direction of someone who makes or can make custom water slide decals. I am actually looking for lettering.
Cheers, Paul.
![Wink :wink:](./images/smilies/icon_wink.gif)
Re: Water slide decals
Posted: Fri Oct 27, 2017 9:32 pm
by Stephen White
Paul, guide to making them here:
http://www.armortek.co.uk/Forum3b/viewt ... =34&t=5793
If you don’t fancy DIY, pm me with what you’re after. Stephen
Posted: Sat Oct 28, 2017 12:31 am
by Tim Page
Posted: Sat Oct 28, 2017 10:58 am
by mark lawson
I have had good results from Pedinghaus simply email him with your requests or send him pictures with the dimensions of what you want and he will make them his turnaround is also fast, yes he speaks English.
Posted: Sat Oct 28, 2017 5:49 pm
by Paul Wills
Thanks for all the reply's and info, I am going to have a go myself then I can't blame anyone if its not what I want
Stephen, I have had a good read through your tutorial and I think I know what I am doing. If it all goes wrong I maybe in touch
Cheers, Paul.
Posted: Sat Oct 28, 2017 6:24 pm
by Stephen White
Great stuff Paul, hope it goes well. Don't hesitate to shout if you want to check anything that's not clear. Perhaps you might take some photos of how it turns out? All the best. Stephen
Posted: Sat Oct 28, 2017 7:19 pm
by Paul Wills
Will do Stephen, I've just ordered the stuff so give me a week or so and I will post my results. if not Ill send you a list of what I want
Paul.
Posted: Sat Oct 28, 2017 9:06 pm
by Chris Hall
Paul -
Making your own decals, especially unusual ones, is relatively straightforward and very satisfying. Just use the right decal paper (inkjet or laser), and don't forget to spray a fixer (like clear varnish) over the top before you put them in water !
The only difficulty is with white decals - obviously home printers don't use white ink .... Unless you go professional, you either need to cut them out of a white background, or print round the edges in a base colour and then touch it with paint. Tricky, but rewarding.
Good luck !
Posted: Sun Nov 05, 2017 8:57 pm
by Paul Wills
Thanks Chris, the paper has arrived and I am just waiting for some of the other stuff to arrive, then I should be able to get going with it this week.
Cheers, Paul.
Posted: Sun Nov 12, 2017 5:53 pm
by Paul Wills
Hi all,
I have had time to set out the decal artwork sheet this weekend, and I have managed to get everything to the required size. I know its a bit basic and most of the lettering is for inside the turret, but let me know what you think.
I have a question that has been bugging me since I started this. I am changing the tiger to Grossdeutschland tiger A23, and in the photos available it shows that it has black helmet markings, not white. One on each of the turret side vision slots and one on the turret bin
![A23 wreck.jpg (184.64 KiB) Viewed 2990 times Black helmet markings on the](./download/file.php?id=15334&t=1)
- Black helmet markings on the
Before I go to print these on the decal sheet, does anyone know why its a black helmet??
Cheers, Paul.
Posted: Sun Nov 12, 2017 6:15 pm
by Stephen White
The artwork looks excellent Paul. I would just check what the printable margins are on your printer to make sure it is all within the print area. Sorry if that’s blindingly obvious and you’ve already done so. Don’t forget to apply a couple of coats of satin varnish over the printed decals before you use. Can’t help re Grossdeutchland but I’m sure someone like David Byrden on Missing Lynx will know if you don’t get an informed answer from here.
All the best.
Posted: Sun Nov 12, 2017 8:02 pm
by Paul Wills
Thanks for the reply Stephen. yes I have already printed a test copy on plain paper to make sure all the sizes are right.
Don't worry, I would prefer you to point it out. life has taught me to listen to others before acting, no one can think of everything, but adding other ideas to your own can make you look like you know what you are doing!
I thought Kent or Per would have been all over the Grossdeutchland question, but if no one gets back in a few days I will drop David a quick email, its been a while since I pestered him.
Paul.
Posted: Sun Nov 12, 2017 10:18 pm
by mark lawson
the Großdeutschland stahlhelm marking could well be red as opposed to black though the division did use both colours as well as white, i'm not aware of the coulours representing different companies i'm also no expert on Großdeutschland.
Posted: Sun Nov 12, 2017 10:27 pm
by Robert E Morey
Paul
Agreed the artwork looks great. What software do you use to make the graphics? I'd like to try making decals.
Regarding the GD, I don't profess to be any expert.
But what I see from my books:
Black helmet = low visibility, ie heavy combat tanks, Tiger, Panther w 3 color camo
Stug Abt = white helmet w/black outline, Stug III w 3 color camo
Soft skins: white, black or white with black outline
Panzer grey vehicles (early war): white helmet or white outline helmet
PzGr Div Brandenburg - red helmet
Fuhrer Begleit Rgt - yellow helmet
Fuhrer Grenadier Rgt - Blue helmet
I have a photo of Oberst (Colonel) Langkiet's Panther A, GD pz regiment Commander - helmet is black, or very dark color.
Above from: Squadron Panzer colors III and Squadron Pz Gren Div Grossdeutschland
Hope that helps,
Posted: Sun Nov 12, 2017 10:46 pm
by Stephen White
Bob, re software for decals, see the Knowledge Base topic which covers the subject (link on a previous post). Paul used MSWord here, which is fine for lettering but for most I would suggest using PowerPoint. It’s much more flexible but is not that much more difficult to learn for anyone new to this. If you really want to refine your decals, an editing package such as Photoshop Essentials is recommended. The KB topic covers that too. Regards. Stephen
