hi, I acquired a king tiger seen on this forum earlier in the year painted gloss railway green.thats not a problem it gives me something to do in the winter months.its the wiring I cant sort.everything seems ok as per the books supplied but the limit switches control the turret turn instead of barrel up and down , the recoil works ok but does not retract when power down.
also something burnt out the left drive motor costing me £300. any advise would be greatfully received.
thanks,
Nigel
NOW OPEN
CLICK HERE FOR MORE DETAILS
NOW OPEN
green king tiger
- Been liked: 11 times
- Has liked: 1421 times
- Been liked: 1603 times
Re: green king tiger
Which motion pack does it have ? The Armortek branded modules or the earlier Electronize ones ?
Not sure what you mean ? When it powers up it should go through a slow cycle to make sure the barrel ends up in the right place but when you power it off it shouldn't do anything.
it has armortek modules as supplied in 2013
the barrel comes out to correct length when switched on and retracts when turned off, well it did for the first few days
That's just the servo reacting to the loss of power., which is one of the reasons it goes through the initialisation cycle when switched on.
Whether it happens or not is down to the servo innards, not the design or operation of the recoil module.
all sorted after reading books twice and going over all the wires 6 times I found which wire was wrong and now all seems ok,just wait for the smoke.
thanks for your advice
