King Tiger Parts Update
Posted: Sun Jul 13, 2008 2:10 am
Hi Guys
Here is a update on King Tiger Parts available. All parts are available for shipping within about two weeks unless otherwise noted. A 25% deposit is required on all orders over $200.00 with balance due when ready to ship. Orders under $200.00 require full payment.
King Tiger Parts.
TT01-01mw Tiger 1, 2 & Jagdtiger Hammer (Metal Head Wood Handle)with fittings 25.00
TT01-01mwk Tiger 1, 2 & Jagdtiger Hammer as a kit with wood handle Fitted 15.00
TT01-02mw Tiger 1 & 2 Axe (Metal Head Wood Handle)with fittings 25.00
TT01-02mwk Tiger 1 & 2 Axe as a kit with wood handle Fitted 15.00
TT01-03Lmw Tiger 2 & Jagdtiger Shovel Long Handle (Metal Head Wood Handle)with fittings 27.50
TT01-03Lmwk Tiger 2 & Jagdtiger Shovel Long Handle as a kit with wood handle Fitted 17.50
Set also comes with handle end stop bracket not shown in picture.
TT01-06ma Tiger 2 & Jagdtiger Wire Cutters (Metal) with fittings 17.00
TT01-06mak Tiger 2 & Jagdtiger Wire Cutters (Metal) as a Kit 11.00
TT01-08ma Tiger 2 & JT Pry Bar (Metal) with fittings 20.00
TT01-08mak Tiger 2 & JT Pry Bar (Metal) with fittings Kit 12.50
TT03c Tiger 2 Tank Tow Ropes with cast brass brackets and Brass/Wood Cleaning Rod as TT03a with long C/Rod 175.00
TT03ck Tiger 2 Tank Tow Ropes, Brass Cleaning Rod Ends as TT03c as a kit 110.00
TT03d Tiger 2 Tank Tow Ropes with white metal cast brackets and Alum/Wood Working Cleaning as TT03b with long C/Rod 100.00
TT03dk Tiger 2 Tank Tow Ropes, Alum Cleaning Rod Ends as TT03d as a Kit 65.00
TT04-02 Jack Block Set Assembled Wood Block Brass Photo-etched Fittings 60.00
TT04-02k Jack Block Set in Kit Form Wood Block Brass Photo-etched Fittings 30.00
This is the early jack block fittings, the later type had a wing nut clamp to hold the block strap, will make this one as well. The strap was fitted across the block as opposed to vertical as on the Tiger 1.
TT04-04 Tiger 2 & Jagdtiger Start Crank 30.00
This is a correct scale start crack 10.2" long.
TT05-02A Tiger I, II and Jagdtiger "C" Shackle Pair, with working wing nuts assembled. $65.00
TT05-02AK Tiger I, II and Jagdtiger "C" Shackle Pair, with working wing nuts kit. $45.00
TT05-03 Tiger II and Jagdtiger "U" Shackles Set of 4 $40.00
TT05-03-6 Tiger II "U" Shackles Set of 6 $60.00
TT11 Tiger 1 & 2 MG Mount and Cupola Ring 90.00
TT11k Tiger 1 & 2 MG Mount and Cupola Ring as a kit 60.00
TT12 Tiger 1, 2 & Jagdtiger Track Tow Rope Late Version with brass photo etched fittings 60.00
TT12k Tiger 1, 2 & Jagdtiger Track Tow Rope Late as TT12 as a Kit 30.00 (Catalog price error at $25.00)
TT22 Tiger 1 & 2 Air Vent Late Type Deluxe Set 60.00
TT22a Tiger 1 & 2Air Vent Late Type Basic Set 25.00
TT37A Tiger 1 and 2 Late Cupola Assembled $550.00
Available in about 2 months.
TT37K Tiger 1 and 2 Late Cupola Kit $350.00
TT37K1 Tiger 1 and 2 Armortek Upgrade Kit $260.00
TT37K2 Tiger 1 and 2 Armortek/V.Abbott Upgrade Kit $225.00
TT37K3 Tiger 1 and 2 Periscopes Kit $160.00
TT37K4 Tiger 1 and 2 Periscopes Top Kit $60.00
TT37K5 Tiger 1 and 2 Periscopes Cover Kit $45.00
TT38 Tiger 1 & 2 Late Production Deluxe Loaders Periscope Assembled $80.00
TT38K Tiger 1 & 2 Late Production Deluxe Loaders Periscope Kit $50.00
TT38A Tiger 1 & 2 Late Production Basic Loaders Periscope Assembled $40.00
TT38AK Tiger 1 & 2 Late Production Basic Loaders Periscope Kit $27.50
GENT002 Fire Extinguisher Set (Late Type) 45.00
GENT002k Fire Extinguisher Set (Late Type) as a Kit 25.00
GENT007a Antennenfuss (flexible base) without wing nut and strap (For GENT008a & b) 18.00
GENT007b Antennenfuss (flexible base) with wing nut and strap (For straight rod antenna) 25.00
GENT08a 1.4m Stab Antenna with strap and wing nut. 20.00
GENT08b 2m Stab Antenna with strap and wing nut. 20.00
Gent015 Square Headed Hammer Wood Handle 25.00
Some King Tigers were fitted with square headed hammers.
IDF01 Large Swastika ID Flag 6â€
King Tiger Parts.
