Hi Chaps
Just a quick intro, I am now the proud new owner of a Pak 43/41 - which shall be known as "Scharnhorst" when built.
Myself and my Dad (bought it as a joint project, as he is a retired agricultural engineer) are now about 2/3 thirds of the way in
Have managed to get everything to fit/work so far - with some severe fettling - and I am learning to take the "easy to assemble" moniker with an equally severe pinch of salt
One thing that has my Dad totally stumped however are the recoil spades; we have built them twice (second time with new set of parts) and they simply cannot work - there is insufficient travel to either unlock them or engage them with the hooks at the end of the trail legs (by a good 1/8").
Has anybody else encountered this problem
Answers on a post card please Shep
Pak 43/41 - Non functional recoil spades?
- Been liked: 2 times
- Been liked: 3058 times
Re: Pak 43/41 - Non functional recoil spades?
Hi Leon
Most guys seem to have built this kit without to much fettling. We have put three together here and have not encountered any special assembly problems.
I can assure you that the spade assembly does function well. If your model does not, then you have probably not assembled it correctly. Remember if you find anything beyond your capability, you can always send the specific parts back to us, and we can assemble it for you.
- Has liked: 1195 times
- Been liked: 1382 times
"A picture is worth a thousand words" - a few pictures of the trail ends from different angles might help us to see if there is anything obviously wrong or misaligned with them.
Hi Chaps
Most helpful :
I will see if I can sort some pics out.
Much appreciated
Leon
Most helpful :
Much appreciated
Leon
