Charging Lead
Bryan Brown
Has liked: 395 times
Been liked: 9 times
Charging Lead
Post by Bryan Brown »
I am looking for a way of being able to have a charging socket on the quad to which I can have access without having to keep removing the top to re charge the batteries. Has anyone been able to do this and if so which socket did they use and where did they place the socket.
michael hilton
Has liked: 1564 times
Been liked: 835 times
Re: Charging Lead
Post by michael hilton »
Hello Bryan, I have routed the leads down through the hole in the equipment trays. They exit through the side lockers. I then split the main battery lead using a E5 connectors. The batteries can then be isolated and charged. The second side locker holds the stop/start switch. Both sockets and switch are hidden by the locker doors. Unplug the E5 connector then plug your charger into the isolated battery side. I tag all my electrical connections, as I easily forget what goes where :) .....Mick.
Bryan,enlarge the photo for a close look
Bryan Brown
Been liked: 9 times
Re: Charging Lead
Thanks for your prompt :D :D reply
Steve Ellis
Has liked: 34 times
Been liked: 26 times
Re: Charging Lead
Post by Steve Ellis »
Hi Michael
Hope alls well, could you tell me where you purchased your £5 connectors from please.
Your set up for the Quad is very impressive, hopefully by the summer the new workshop will be fully operational and I can get back to building my Quad after almost a 2 years break.
And before you ask we went traveling for 6 months and then brought a house, one with enough room in the back garden for a decent sized work shop.
Look forward to hearing from you
Kind Regards
