Could anyone help me ...Not sure how to wire up an LED machine gun manufactured by Steve Winstone in order that it flashes when the appropriate sound is selected .If anyone can help with this it would be greatly appreciated.i believe Adrian Harris is the man who will be able to help.
hope someone can help
Rob Coomber
NOW OPEN
CLICK HERE FOR MORE DETAILS
NOW OPEN
LED machine gun wiring on king tiger
- Has liked: 1421 times
- Been liked: 1603 times
Re: LED machine gun wiring on king tiger
Which amplifier module do you have ?
On the Mk1 Amplifier Module, it goes onto the which connector next to the volume control. The positive connection goes to the centre pin and the negative to the pin furthest from the volume control.
On the newer Mk2 Audio Module, I believe it goes onto LED output 4, with the negative at the top and the positive at the bottom.
I don't know if Steve sends them out with colour coded wires, but the negative connection on an LED goes to the side with the flat on the case, and it has the larger electrode inside the 'bulb'.
If you get it the wrong way round, you can't do any harm, as an LED just won't conduct if connected backwards.
Thank you so much for the info will be in touch if further assistance required.
regards, Rob
regards, Rob
