late tiger bullet ring guard
Posted: Mon Jun 23, 2008 10:04 pm
by David Gray
can anyone tell me what type of bolts were used on the bullet
ring, were they countersunk or hex head bolts
thanks Dave gray :D
Posted: Mon Jun 23, 2008 10:38 pm
by Martin von Bargen
Hi David
In the assembly instructions on page 30 is only the bullet ring listened. The fasteners provided are not listened. You can see the correct screws in the Armortek Gallery under late Tiger, second page, first picture.
I don't know the correct name of the screws in English, sorry!
I hope that I could help a little.
Martin
Posted: Tue Jun 24, 2008 5:36 pm
by David Gray
hi Martin , sorry i didnt mean the armortek one, iwant to know
what , was used on the real one. i have Mike stannards bullet
ring but im not shore if the countersink screws supplied
represtent the real tank.
Dave :D
Posted: Tue Jun 24, 2008 7:21 pm
by Mike Stannard (toyrific)
Hi David
I believe the real ring was welded in place or maybe held by flush fitting bolts, once you have fitted the ring fill in the screw holes and it will look correct.
Mike
Posted: Tue Jun 24, 2008 8:18 pm
by David Gray
Thanks for that Mike , i will do that
regards Dave :D
ps Mike keep me posted on the tiger cupola , its the last part i need
Posted: Tue Jun 24, 2008 10:11 pm
by David Ward
The turret ring guard consisted of three identical and interchangeable segments. They had seven bolt holes in each but only five holes in each were used. The holes used differed between the position of the segment so there will be two empty holes in each. Check out the Tiger 1 info site.
http://tiger1.info/EN/TurretRingProtector.html
Posted: Tue Jun 24, 2008 11:18 pm
by Tim Bowman
David W
Great info. I noticed in a few photos there were holes as well. Could not make out fasteners but definitely holes.
Thanks for the link.
Posted: Wed Jun 25, 2008 1:09 am
Looks like the bolted in place is the correct way, the likely reason bolts do not show up on the rings is they used sharply counter sunk bolts which ended up flush with the surface and when painted would only be seen in a very close photo. The reason my ring set is in six sections is I was not able to cast three sections as they were to long for the mold.
Mike
Posted: Wed Jun 25, 2008 8:14 pm
by David Gray
Thanks for that David, what i have decided to do is, counterbore
the already countersunk holes in Mikes ring and fit the ring with
7BA bolts with the heads flush. i am quite pleased with the result
Dave :D
