Tiger 1 hard target restoration ?
- Has liked: 2272 times
- Been liked: 7154 times
The old Tiger 1 has been brought up from the range to be used as a vehicle for the Bergepanther to recover in various scenarios.
I want to keep a lot of the battle damage as is, where possible, the near side has taken most of the hits considerably deforming the plates and top deck, the road wheels x8 are beyond repair on this side also..see pics
Re: Tiger 1 hard target restoration ?
Some interesting pics of the damage
Interesting patina of the interior
All of the bent and twisted parts were straightened and bolted back together!
I have used ali plate for the hatch and manufactured new hinges from loader vision scope castings with 3mm galvanised wire for the grab handles, I will ad more details as I go.
- Has liked: 60 times
- Been liked: 33 times
Crikey Mr Woollard that is a restoration and a half. I thought my slow restoration of 1331 and 311 was difficult enough but a walk in the park next to your task! Quality of these models does indeed shine through. 1331 stood for 4 years outside but after an hours tinkering with the electrickery it burst into life and ran round the garden. Didn't have to withstand live rounds though
Hi Peter, tis a labour of love that we do to be sure, I'm thinking about leaving the damaged side as is but I also want to restore it all at the same time, all that character would be lost..hundreds of hours and lots of expense to get it looking this rough, modelling battle damage is more difficult to achieve than any other effect, how should I portray the weld seams?
All good fun though regards Phil
More HV damage pics
Down on the range
- HESH impact Tiger1
- Hesh round at Tiger1 002_0002.jpg (38.16 KiB) Viewed 5472 times
- Hesh round as it impacts side plate , Tiger1
- Hesh round at Tiger1 001_0001.jpg (43.5 KiB) Viewed 5472 times
Update
Experimental diorama photography, some old some new, nothing to do with the restoration
- Tiger1 european building wrecked 014_0001.jpg (22.06 KiB) Viewed 5311 times
- Tiger1 european building wrecked 015_0001.jpg (22.2 KiB) Viewed 5311 times
- 04_10_2004 12_08_0002.jpg (53.51 KiB) Viewed 5311 times
- 04_10_2004 12_08_0001.jpg (52.02 KiB) Viewed 5311 times
- 04_10_2004 13_43_0001.jpg (40.77 KiB) Viewed 5311 times
Just in case you wondered what it would be like inside an Armortek Tiger1 taking hits
- This round fired into the fuel tank, travelled on into the engine bay, the diameter of the round was 12 mm and contained .5 of a gram of other material for effect
- Magnum heat round Tiger1 004_0002.jpg (35.74 KiB) Viewed 5291 times
Last edited by Phil Woollard on Fri Dec 02, 2016 8:30 am, edited 3 times in total.
Rounds fired into the running gear of our Tiger1 often went right through the overlapping road wheels
The Tiger 2 used for firing the live rounds at the Tiger 1 hard target.
- A small amount of black powder was added to the niro mix to produce a more period smoke effect.
- Tiger2 firing#3 002_0004.jpg (25.74 KiB) Viewed 5081 times
- You can just make out the lanyard coming from the rear of the turret.
- Tiger2 firing#3 002_0003.jpg (28.26 KiB) Viewed 5081 times
- Even at this scale the weight of the model provides a very stable firing platform with little recoil through the chassis.
- Tiger2 firing#3 002_0002.jpg (29.12 KiB) Viewed 5081 times
- Excellent shot of the gas venting sideways from the muzzel break
- Tiger2 firing#3 002_0005.jpg (31.36 KiB) Viewed 5081 times
It continues.
We still have this old Tiger chassis and it's next on the list for some restoration, this is the Tiger being hit by aircraft cannon in the video.
I'm thinking about this quick fix for the missing early wheels, was this ever done in the field I wonder, I'm sure that I may have seen an old photo of maybe a single late wheel used in this way ?
