Front Axle Assembly
Posted: Thu Oct 06, 2016 12:39 pm
by Armortek
There is a drawing error on drawing number 9, Front axle. The differential is shown with crown wheel on the left hand side. It should be assembled with the crown wheel on the right hand side.
Additionally it is essential to ensure that the two springs EM0515 are fully seated in the output drive cups, of the differential.
Re: Front Axle Assembly
Posted: Thu Oct 06, 2016 8:28 pm
by Shaun Hunt
Mark,
Can i ask the purpose of the 2 springs as the rear axel does not have the springs.
Posted: Thu Oct 06, 2016 8:38 pm
by Walter Mackinnon
Hi Shaun.
The springs are to keep the half shafts in the front wheels as they turn to steer.Regards Walter.
Posted: Thu Oct 06, 2016 8:52 pm
by Shaun Hunt
Thanks Walter i did think that but wasn't completely sure.
Posted: Sun Oct 09, 2016 6:33 pm
by John Clarke
Thanks for the heads up on the front axle. I suppose the axles turn in the opposite direction.
Here's a chestnut, don't put 3mm x 14mm pins in the rear half shafts as the bible says, they won't fit down the 12mm rear axle tube. Find some 3mm x 12mm in the parts bag, I'm sure there's a few extras.
Go to Joe and Johns Quad and see how you can hold the winch outer frame together.
l]Image[/URL]
