Surfaces/conditions to avoid driving on/in?
Sam Hough
Has liked: 68 times
Been liked: 53 times
Post by Sam Hough »
Are there any places to particularly avoid driving?
We have a gravel drive, that seems like it would do horrible things to the tracks.
Anything else to stay away from?
Sam
Has liked: 1365 times
Been liked: 1564 times
Re: Surfaces/conditions to avoid driving on/in?
Gravel is particularly bad for tracks.
The bare earth pile at TankFest had a few hidden stones which claimed a few links, so it's always worth a recon trip.
Long grass can get wrapped around sprockets, axles and idlers but doesn't usually cause any damage.
Snow isn't too bad as long as you let the tank cool down to the ambient temperature before running it, otherwise the snow performs exactly as in real life and melts between the wheels before refreezing and locking everything up.
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Thanks Adrian,
Will stick to back garden if I can work out how to get it there.
It has made a right mess of my painted garage floor! Nice and slippy though as I break it in and fiddle with track tension.
Sam
Chris Hall
Has liked: 516 times
Been liked: 674 times
Post by Chris Hall »
I've got a gravel drive too, with grass on the other side. So I drive very slowly (especially with the Panther), and in a straight line, over the gravel to reach the green fields beyond .....
Apart from that, what Adrian said. These busses will go over pretty well anything with care, but an initial survey pays dividends. That earth mound at Tankfest initially caused grief to Tigers, Panthers and Shermans (although the Mark IV's sailed over it ! :D) but once it became impacted it was fine for everyone.
The only thing I personally would avoid like the plague would be deep water, especially if it's muddy / gritty. Apart from that, don't let worry spoil your fun !
Can't wait for the chance to run in snow .....
All the best,
mark lawson
Has liked: 2491 times
Been liked: 443 times
Post by mark lawson »
If you have to drive/turn on gravel then use some boards especially to turn the tank this can and will fill the tracks casing them to jam and most likely breaking track links small gravel can be worse than the larger stuff.
RAG Militärmodellbau
IG Militärmodellbau
Sam Hough
Has liked: 68 times
Post by Sam Hough »
After months of ignoring the overgrown back garden path it has suddenly become urgent job ;)
Graham Hough
Been liked: 19 times
Post by Graham Hough »
It would be good to get that done before next week, I less job for us ;)
Sam Hough
Has liked: 68 times
Post by Sam Hough »
Is done although the tracks managed to pull out a huge weed.
Doing lots of tinkering with track tension. Also worried as front left road wheel doesn't touch the track. Could be wrong position? I think you said you had not ground flats on the torsion bars yet.
Graham Hough
Yes until I was certain that the torsion bars were in the correct position they are only clamped in position. If we are happy with the angle of the suspension arm then I will grind the flats.
