Wiring things up need help
Posted: Fri Jun 06, 2008 6:41 pm
by Derek Attree
Hi Guys
I have just unpacked my Option Pack 1 and sound unit
and I think I may need some advice the sound unit has 3 identical
leads with recever type plugs on and I cant see what goes where?
In fairness I have only had a quick look and not spent much time yet
but is there any clues?
There used to be some photos of OP1 and 2 buy they were very small and I cant find them.
I hope someone knows
Posted: Fri Jun 06, 2008 7:18 pm
by Tim Bowman
Hi Derek
Once you get everything laid out it becomes pretty straight forward. Just cross-check the images in the manual(assuming they are the same as I had for the Panther) and the schematic. Of course I may not be the best to give out advice as my MG sound still doesn't work.
Are these the pictures you are thinking of?
Good luck
Posted: Fri Jun 06, 2008 7:48 pm
by leesellars
Hello Derek
The Rc leads from the black plug with 4 leads in. The top is the power next down is the input for ESP 1 the next one down is the input for ESP 2 and the bottom lead is the input from the Reciever.To get the full manual it can be downloaded from
www.benedini.de
lee
Posted: Sat Jun 07, 2008 4:55 pm
by Derek Attree
Hi Tim and Lee
Tim wireing for the Panther is what I am doing I am getting there
slowly the pictures are what I was looking for.
Its a shame they are not bigger!!!
(Mark could somthing be done there)
Lee I have desided to get things running then add the sound unit later.
Thanks for the help guys
SIZE
Posted: Sat Jun 07, 2008 6:11 pm
by Graham Ord
Try pressing ALT AND PRINT SCREEN when you are looking at the picture.
Open a photo editor program.
Open a NEW FILE
Under EDIT click PASTE
You can now zoom in, and change picture as you want and save it and print it if required.
Posted: Sat Jun 07, 2008 9:27 pm
by Derek Attree
Hi Greaham
thanks for that tip Its a big help.
