Tiger1 production in Birmingham
Posted: Thu Jan 07, 2016 2:31 pm
Hello everyone and Happy New Year.
I'm new to 1:6 and thought I'd post the occasional update on my build.
First comment is what a well engineered kit it is the panel fit is very good and I haven't had a problem with either the hull basic structure or the turret.
Having studied many build posts over the last few months in anticipation of my kit arriving I was hoping to add some extra detail here and there. The first opportunity I got was to replicate the pannier gusset details as per John Fitzsimons. The following step by step process is how I did mine;
1) I measured the location of the rivet holes and cut outs – mirroring the Armortek vertical flange locations except staggered. I transferred the measurements to a 1m strip of 30mmx2mm aluminium. Note that I’d already practiced with some 1.5mm ally sheet but it didn’t work out very well when I came to separate the two halves ending up with something resembling 2 very long Vesta deep fried noodles!.
The 2mm strip is harder, as it’s been rolled and it seems to cut without as much distortion. 2) All the hole positions were centre dotted. Note that with a couple of exceptions the main hole spacing is at 24.5mm centres. 3) I used a pillar drill with 3mm holes for my copper rivets and a 21mm hole cutter for the main cut outs. I screwed the ally strip to some wood every 150mm so that the drill didn’t grab as it passed through and also so I’d got something substantial to hold and clamp to the pillar drill vice.
4) In this manner all the holes can be cut swiftly and in line using the cutter – the final diameter of the cut holes was actually 21.5mm. 5) I marked a 5mm line either side of the C/L along the strip so that the finished gusset would be 10mm wide and used a niblick to separate the two halves. I’d tried using snips on my practice piece but they appeared to induce a stretch to the alloy which was almost impossible to rectify (ref. noodles above). 6) Next it was simply a matter of positioning the strips and drilling rivet holes through the pannier and securing the new flange with Loctited rivets. You could of course rivet them conventionally. I shall simply cut and grind the ends of the rivets flush with the inside of the pannier floor. A tip here with installing rivets in this way, I found that I had to countersink the rivet holes slightly to make the rivet head sit perfectly flush, I think it’s part of the rivet head forming process.
You'll see that I’ve already countersunk some fasteners for the hull floor and into the hull sides.
I am very satisfied with the results, it just remains to do the welds, for which I may try syringe-applied plastic padding. I’ll let you know how that pans out, hopefully better than my experiments with a hot-glue gun!.
