Spray Painting Booth
Has liked: 1479 times
Been liked: 1684 times
Has anyone ever considered using one of these pop-up spray tanning tents as a disposable painting booth ?
Pros:
They are available for around a tenner on ebay
They are designed to contain over-spray
They should prevent any odd drafts affecting the spray if used outdoors
If you get one with a door, it could be shut after painting to allow
the paint to dry without fear of insects or dust getting stuck to it
Cons:
The cheap ones seem to be mainly Barbie Pink :shock: :oops:
Re: Spray Painting Booth
anything is worth a try at that money, spraying in a confined space is not the best thing, extraction is the main problem as we know, my method, standard household 3 speed fan directed at the job on low speed out the garage door, the neighbours say whats that nice smell, its like "pair drops sweets", every ones happy, regards simon.
From a health point of view due to the chemicals/particles or because the over-spray will be blown around inside the tent and might ruin the paint finish ?
