Smoker
Posted: Mon Jul 06, 2015 10:38 am
by Robin Ellis
Having problems getting my 24v smoker to work.Up till now it has been fine.Maybe I over filled it! Adrian's unit lights up but still no smoke.
Any ideas?
Re: Smoker
Posted: Mon Jul 06, 2015 12:14 pm
Does the fan work when the module lights up ?
Can you feel the smoke case warming up after it has been on a while ?
The elements do have a fixed lifespan, so it may just have expired naturally.
If the thing stays cold, then I'm sure Gill will be happy to sell you a new element for it
Re: Smoker
Posted: Mon Jul 06, 2015 1:14 pm
by Robin Ellis
Thanks for your reply Adrian. No I have not checked to see if fan is working.Will see later.
Re: Smoker
Posted: Fri Jul 10, 2015 3:55 pm
by Robin Ellis
Hi Adrian, today I stripped down the smoker unit to find that the 'matting' was like a piece of crispy bacon, so I ordered a new piece.Also a new element, plus an element tube
and holder. No wonder it was not working!
Re: Smoker
Posted: Fri Jul 10, 2015 5:25 pm
Hmmm, bacon
Is yours the original smoker
I guess yours will be one of the oldest running Tigers on the Forum.
Re: Smoker
Posted: Fri Jul 10, 2015 8:37 pm
by Robin Ellis
As far as I know,it is the current version.
Re: Smoker
Posted: Sat Jul 11, 2015 6:18 pm
by Robin Ellis
Hi Adrian, what smoke oil do you use? I have been using baby oil until recently When I tried Seuthe smoke oil which is much thinner than the baby oil. Maybe the Seuthe is burning up to quickly. Your thoughts please.
Re: Smoker
Posted: Sat Jul 11, 2015 6:36 pm
by John Heath
You might want to try Venu Smoke Fluid. It's intended for stage fog units but is ideal for tank smoke units and is quite inexpensive. It doesn't leave any oily residue but gives a decent volume of smoke. I've used the medium and thick versions.
