Hi everyone I purchased the pak43/41 kit at tiger day Bovinton and am a little confused. on building the kit I appear to need over 50 M3x10 button HD bolts however only 6 are supplied with the kit.
Are the plans wrong as I seem to have 77 M3x6 button and only appear to need around 30, anyone help please
Pak43/41 kit bolt issue
- Has liked: 8 times
- Been liked: 4 times
Re: Pak43/41 kit bolt issue
Hi Dave
Read my post on Rodneys Pak43/41 regarding the bolt issue.
Regards Walter.
Regards Walter.
Re: Pak43/41 kit
Hi all builders.
When you get to page 12 I found it easier to fit the brackets cno214/215 to cn0136 and then to bolt on the inside of the shield, then super glued the nuts in place, then removed it, holding the outer shield upside down slipped the cone head bolts through the holes, covered with a large cloth moulded to the shield, turned it over and fitted the spacers then fitted the inner shield, DONT FORGET TO FIT THE PICK AXE BRACKETS. I hope this of some help
Regards Walter.
Regards Walter.
