Connections
Posted: Sat Apr 25, 2015 7:43 am
by Ray Brown
How many times have you connected all the wires & leads and have had to disconnect them for whatever reason and then re-connect everything. I've decided to try this..................... Each module has has letter with each position numbered. Each lead/connection has a corresponding letter/number. Therefore, match letter/number = straight away no frustration. Works great.
Re: Connections
Posted: Sat Apr 25, 2015 8:25 am
by Steen Vøler
Hi Ray
yes it's a great way to secure the reassembling after an overhaul.
I did the same thing on my jagdpanther
Re: Connections
Posted: Sat Apr 25, 2015 1:15 pm
by Steve Stuart
Hi Ray
Good to see it coming together!
Re: Connections
Posted: Sat Apr 25, 2015 3:13 pm
by Mark Adams
I see the Mk IV motion packs are finally shipping! Is it an easy install? I've been holding off on building mine so I could install early on.
Cool!
Re: Connections
Posted: Sun Apr 26, 2015 2:29 am
by Ray Brown
The motor installation was a bit finicky but okay. Ensure you put the motor mounts on before securing the armour plates.
Ray
