Blown Fuse
Debbie Ansell
Blown Fuse
Post by Debbie Ansell »
Can anyone help solve my problem with blowing main fuse. Runs well on bench. Elevation, rotation tracks smoke all OK. As soon as on ground and pulling down weight main fuse is blown after 15 minutes. Power pack was received with 35amp Manual says 30 amp. Any ideas?
Allan Carlsen
Been liked: 128 times
Re: Blown Fuse
Post by Allan Carlsen »
Hello Ken
I have a similar problem (I got a KT) when I put my KT down to the ground and reversing the tank - my fuse blow (30 amp). I have no problem driving forward and back.
Solution here is, use both engines at the same time when you turn your tank, If the problem is the same. Try to google the problem here on this forum.
Sorry about my english, hope you understand my answers. :oops:
Been liked: 3713 times
Re: Blown Fuse
Hello guys
The main fuse should be 40amps, not 30 or 35. Your kits should have been shipped with a 40 amp fuse in place. If not this was an error. All the big tanks are fused at 40amps, only the smaller vehicles use lower rated fuses.
Has liked: 1495 times
Been liked: 1699 times
Re: Blown Fuse
I'm sure I've read somewhere that, as the battery voltage drops, the current increases to compensate, so could it be the battery which is at fault ?
Could you wire up a DVM to see how the battery voltage looks as you run the tank ?
Or you could go by the colour of the LED in the Power Module, if you have that fitted. If it ever goes red whilst running the tank, then the battery voltage is too low.
Debbie Ansell
Re: Blown Fuse
Thanks all for prompt responses. Will do as you suggest. Will get some 40 amp fuses and keep you updated. Regards.
