I have an first generation mid-production Tiger with the older style control units. Just got my 4QD's (with Benedini sound) from Gill and plugged them in. It didn't go so well. Seems I didn't look at the wiring diagram close enough as I missed the relay in the control box. Too much current across the switch messed it up and blew a fuse on the left side. My control box with its original wiring doesn't have the relay. Would one of the relay's from the older setup work? If so, what are the pin outs?
Rich
Any Mid-Production Owners Convert to 4QD's?
- Rich Stinchcomb
- Has liked: 3 times
- Been liked: 1 time
"All you saw in your imagination was the muzzle of an 88 behind each leaf." - British Tank Commander Andrew Wilson
