Panzer III Tools and Accessories
Posted: Thu May 01, 2008 4:35 am
Hi Guys
Here are a few pictures of Panzer III items I have been working on. Most of them are from my current products, some require new type fitting and some are only prototypes. These will not be available for a few months, but I would like to hear if you have any interest in them. I will not go into production on these until we see what comes with the Panzer III, no point in making parts if they are not needed.
Jack Block and Carrier. There are two basic carriers, I will be offering both. One type is mounted direct to the fender, the other is mounted above to 'S' Shackles. Pry Bars square and round types.
Start Crank, Wire Cutters and Axe.
Shovel, Antenna Trough (prototype brackets not correct), Antenna Base
(antenna base is only a mock up, this will have all detail).
Tow Ropes
Other potential parts that may be made.
Convoy Light and Rear Side Light with correct brackets for Panzer III
Turret Mounted Smoke Lunchers
Antenna Trough for 1.4mm Antenna (Command Tanks)
Sternantenna D Basic (Command Tanks)
Frame Antenna (Command Tanks)
Telescoping mast for Sternantenna D (Command Tanks)
Step (Command Tanks)
Cleaning Rod and Mounts.
Jack and Mounts.
Current production parts that are compatible to Panzer III
Gent002 Late Fire Extinguisher
Gent003 Early Fire Extinguisher
TT11-01a MG AA Mount
PZIVT026 Bosch Head Lamp
Deck03 Decking Dot Pattern
IDF01 to 04 ID Flags
Tow Ropes
Jack and Mounts.
