5 Axis CNC in action
Posted: Fri Oct 17, 2014 10:44 am
by Armortek
http://youtu.be/jdIVc140Gbg
A short clip showing the machining of the Tiger 1, lower hull plates, in the new 5 Axis machining centre.
Re: 5 Axis CNC in action
Posted: Fri Oct 17, 2014 1:09 pm
by Steen Vøler
Wow that is very impressive
Posted: Sat Oct 18, 2014 1:27 pm
by David M Wilks
Mesmerising !,how long does it take to program a piece like that ?
Posted: Sat Oct 18, 2014 1:41 pm
by Armortek
It took Mark about 20 minutes to programme that part, the clip you can see is only part of that particular operation which in total took 4 minutes per part.
Posted: Sat Oct 18, 2014 5:15 pm
by Luc De Weirdt
A peep behind the scenes.
I found this very interesting to see.
Posted: Sat Oct 18, 2014 8:35 pm
Quite a lot of coolant being squirted around...
I'm interested to know if Mark has to know which operations the machine can handle, or whether the CAM software knows out which ones the machine can manage ?
Posted: Sun Oct 19, 2014 9:15 am
by Armortek
Adrian Harris wrote:Quite a lot of coolant being squirted around...
Mark chooses, he does not use CAM software but programmes each machine using G code.
