Can anyone let me know how many castellated nuts are required for a Late Tiger 1
I'll be fitting Steve's bump stops, so that's twelve, plus the rear tow hitch needs four, but I'm not sure if are of the any other fittings require them
Castellated Nuts per tank
- Has liked: 1365 times
- Been liked: 1564 times
- Has liked: 5 times
- Been liked: 629 times
Re: Castellated Nuts per tank
That's all I used unless you want to start on the interior. Used a few inside.
John
John
- Has liked: 427 times
- Been liked: 21 times
I found another 10 are required for the front hull fillets, but you have to recess the plates ,there are some good photos from the Vimoutiers and Samur Tigers around. Dave W
Thanks both.
I was at the Vimoutiers Tiger on the 3rd June, so have some photos of the fillets
