Can anybody help.I have connected up my amplifier and speakers to my KT,I have left the turret disconnected from the model at present as I need to do a road test ,now the tank will move but I receive no sound from the tank.
I have seen the topic about the sound system burned ,and how to change the mode,but I cannot find any button within my amplifier unit to press or is that because I am using the Armortek option pack.
I can not find any mention of the sound unit in any of the options assembly instructions so I expected this unit to be a plug and play so please can anybody give me a clue .
King TIger Sound Option System problem
- Has liked: 1421 times
- Been liked: 1603 times
Re: King TIger Sound Option System problem
You need to remove the four screws in the top of the Amplifier module and remove the lid.
The Benedini sound card is plugged into the main amplifier board.
On the Benedini board, there is a small square switch with a round button, beside two of the main chips. This is the programming button.
- Been liked: 41 times
Hi Gary,
Just got to that stage myself, I had the amp manual missing so if you have no manual it might help if you ask Gill for a copy for setting up.
Cant give you any advice as not set up myself properly, but if you look at this link it might help copy and paste
http://www.armortek.co.uk/Forum3b/viewt ... =16&t=5057
Hope this help's
Regards Roger
Hope this help's
Regards Roger
- Been liked: 3501 times
Hi Gary
I will send you a copy of the amplifier manual. Sorry if this was not included,
Gill
Gill
Thank you Gill for the instructions,and many thanks for all your help in this matter.
Gary Sullivan
