Here is a major update to the General AFV Section of my catalog, it covers miniature scale wing nuts and eye bolts. 1.6 mm size (Page 2), the KW Cold Start (Page 4), KW MG34 Mounts and Stowage (Page 5), MG34 Gurtsack and Mounts and Miniature Brass Hinges (Page 6).
Gent012W-2A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Wing Nut x 2 $7.00
Gent012W-10A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Wing Nut x 10 $30.00
Gent012N-2A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Scaled Nut x 2 $5.00
Gent012N-10A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Scaled Nut x 10 $20.00
Gent032-AK KW Cold Start for all tanks, halftracks and vehicles as a kit. Wood Floor not included $250.00
Gent032-BK KW Cold Start (I) for vehicles with up to 4 litre engines as a kit. Without stowage fittings $165.00
Gent032-CK KW Cold Start (II) for most tanks as a kit. Without stowage fittings $170.00
Gent032-DK KW Cold Start (III) for most half tracks as a kit. Without stowage fittings $170.00
Gent041-K KW Rifle Rack and Cross Bar as a Kit $50.00
Gent042-K KW Rear MG34 Mount as a Kit $25.00
Gent043-K KW Front MG34 Mount as a Kit $40.00
Gent044A-K KW MG34 Stowage Rack as a Kit (To be used with Gent041-K) $30.00
Gent044B-K KW MG34 Stowage Rack and Cross Bar as a Kit $40.00
Gent045-K KW MG34 Center Mount as a Kit $25.00
Gent046-A KW Floor Boards Assembled $45.00
Gent046-K KW Floor Boards as a Kit (With Insruction on how to assemble) $25.00
Gent047-A MG 34 Gurtsack $50.00
Gent048-A MG 34 Gurtsack Mount $30.00
Gent048-K MG 34 Gurtsack Mount as a Kit $15.00
Gent049-A Miniature 3/8” All Brass Hinges with Screws x 2 (hinge .016” brass) $3.00
Mike
