Steves Centurion
Posted: Fri Jan 10, 2014 10:06 pm
I guess its about time i posted a few photos of my Cent build.
A long way to go yet but an enjoyable build with lots of additional detail that can be added if wanted.
Air defector and tow bar, i still need to find a way to add the central ribs to the air deflector
Rear hull plate repositioned so that the hull sides extend beyond it, upper rear hull side plate has also been extended
Rear deck with added detail
Modified upper deck plate using pins to locate the forward end, additional sheet has also been added on top to simulate the deck overhang
The back end of the upper deck will be fastened with cap heads that sit below the fuel filler caps, 7 dummy bolts have been added between the fuel filler cap locations. The added sheet can be seen overhanging the hull sides.
Center suspension bogie with added detail
Forward suspension bogie with added detail
Additional armor plate added to the hull front, The welding has been started but lots more still to do
