New Eye Bolts, Wing Nuts and Hinges
Posted: Sun Nov 17, 2013 1:09 am
by Mike Stannard (toyrific)
Hi Guys
Here are new products I am offering which many of you may need and can be hard to find.
The wing nuts and eye bolts I had made, I was trying for a US standard size of 1-72 the same size as my cast wing nuts but it did not happen. Long story, not going into details. Any way these were made with a metric size of 1.60 mm as best I can measure, don't have a nut in that size to test them with. I am selling these at about half the price of my original ones, which I will continue to use on many of my products.
Gent012W-2A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Wing Nut x 2 $7.00
Gent012W-10A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Wing Nut x 10 $30.00
Gent012N-2A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Scaled Nut x 2 $5.00
Gent012N-10A 1.6 mm x 12 mm Eye Bolt and 1.6 mm Scaled Nut x 10 $20.00
Miniature Hinges.
I have never been happy with the piano hinges I have used in the past as these were made of a alloy with a brass colored wash and a metal pin which rusts after some time. These new hinges are all brass, can be soldered and will not rust. I found them when searching for hinges for my SdKfz 222 turret grill.
These will have many uses, ideal for ammo boxes and tool boxes.
Gent049-A Miniature 3/8” All Brass Hinges with Screws x 2 (hinge .016” brass) $3.00
Mike
