Flash for gun
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Flash for gun
Post by Steen Vøler »
hi all
Most of us have the MG wired to the benedini to get flash in the mg when firing it
What are the recommendations for a flash for i.e. a 88mm JagdPanther :D
Would really like the flash in the main gun
Any one having this as "plug'n Play" to buy
cheers
Steen
cheers
Steen
mark lawson
Has liked: 2519 times
Been liked: 444 times
Re: Flash for gun
Post by mark lawson »
Steen Kameraden, I use a 10mm LED on my Tiger this can be taken from the spare positive for the MG flash.
Grüße
Mark.
RAG Militärmodellbau
IG Militärmodellbau
Has liked: 1478 times
Been liked: 1682 times
Re: Flash for gun
Hi Steen.
Me again... :roll:
I've fitted a multi-LED flash system into Denny's KT and Panther.
The problem with the JP is that the gun pivot goes through the barrel, making it difficult to get a decent sized lead to feed the LEDs.
For the 75mm barrel, I used three 5mm LEDs, and for the 88mm I used three 8mm LEDs.
The trigger is taken from the Benedini board, as Mark says, but a PIC chip flashes the three LEDs independently, to give a more random effect. The LEDs are yellow and orange, to give a realistic multicoloured flash effect.
Steen Vøler
Has liked: 62 times
Re: Flash for gun
Hi Adrian 8)
Thought you would have a solution for me :D
the barrel will be drilled out so that there will be 100% open barrel end to end.
Could you build one for me and maybe do it so that I can disconnect the cable close to the mantlet where I normally disconnect the barrel for transportation :-)
cheers
Steen
cheers
Steen
Poul Kiaerulf
Re: Flash for gun
Post by Poul Kiaerulf »
I'm listening :wink:
Why not using a flash module as used for photography. Can led's provide the same strong flash ??
best regards
Poul
Re: Flash for gun
Poul.
Some people have used to the xenon flash tube, but to my mind the flash is too fast and too white, which is why I prefer the coloured LED method.
Re: Flash for gun
Here are a couple of videos showing the LED muzzle flash:
Indoors:
Outdoors:
The M4A3 Sherman barrel is not as impressive as the Axis guns it has no muzzle break to catch the colours from the LEDs.
Steen Vøler
Has liked: 62 times
Re: Flash for gun
Hi Adrian
I'm in - lets continue over PM with pricing/delivery etc :D
cheers
Steen
cheers
Steen
Steen Vøler
Has liked: 62 times
Re: Flash for gun
Hi Mark
are there any news on the dates for the RAG event in 2014?
I am travelling to Normandy 4. July to 8. July to be there for the D-Day Landing 70 anniversary so I hope this will not conflict with the RAG dates
cheers
Steen
cheers
Steen
mark lawson
Re: Flash for gun
Steen, Pfingsten next year is the 8th and 9th of June, I will again attend from the 7th, for you it’s a very long drive from Normandy to Munster for 1 day but if you come keep me informed it would be nice to once again meet
Adrian, I would also be interested in this setup, the single LED setup I have is not that visible from the sides
IG Militärmodellbau
phil fitzpatrick
Been liked: 223 times
Re: Flash for gun
Post by phil fitzpatrick »
Hi everyone
Did you see my vidios of my Flash and Recoil on my A34 Comet,on page 19 of my
Comet postings.
There are 3 or 4 vidios taken day and night and showing the flash with
the common Halogen light capsules 12V or 24V,I found 20 to 30Watt best and it was
fed through a Delay off Timer,you see the colours from white yellow to red,with
the time being adjustable.
In one video I tried 100 Watt but it was a bit too slow to start up.
This was all prior to Armortek Flash and Recoil,mine was definatly not a plug and
play job,but the night video colours look really good and the flash still looks
good against the bright sunlight.
