Final images for my mid production Tiger 112 (34 images)
James Tseliki
Been liked: 8 times
Post by James Tseliki »
It is now almost 3 years to the day since I started my mid-Production Tiger 112 ABTEILUNG 508 project. The final segment of the project was the installation and animation of the crew figures.
Animating these dollies with any degree of realism has been challenging considering the technical limitations as well as the relatively low quality miniature servos that are commercially available. Be that as it may, the objective has been to achieve as far as is possible fluidity of movement and to minimise the robotic feel inherent in the dollies. To this effect, a sequence of movements was programmed in a loop repeating itself after a suitable pause.
Adhering to the principal that less is invariably more, I have only used head and some torso movements. The movement of arms was avoided, as it tends to look unconvincing and robotic. To enhance the illusion further, I have used good quality heads, which were re-worked and re-painted. Of course there are other aspects that help create a sense of realism by mimicking as much as possible, the natural movements of the human body, posture, head inclination, co-ordinated head/torso movement, as well as properly fitted uniforms and headgear. I hope these objectives were partially achieved with lots of room left for development and improvement.
I hasten to add at this point, that the animatronics project was a collaborative effort between myself, and my friend and electronics wizard, Howard Kalisch.
During the Armortek Open Day at the Tank Museum at Bovington, I was asked by several people, if it would be possible to post some close-up pictures on the various aspects of my Tiger, so it is with pleasure that I have selected a number of photographs that hopefully illustrate and characterise my approach to tank modelling.
Unfortunately it was not possible to demonstrate the number of features incorporated into 112, including the animated crew. Setting off at 5am for my trek to Bovington is an activity outside my normal comfort zone. As a result I forgot to bring along my controller……. so I exhibited a static model unloaded from my vehicle, all of its 165kgs, by muscle power (thanks again Chris).
Real Maybach 230
Modelled Mayback 230
Churchill Creations
Been liked: 9 times
Re: Final images for my mid production Tiger 112 (34 images)
Post by Churchill Creations »
Very impressive James!
Do you think you can send back the animatronic figures please, I could really do with them.
Sym.
Animatronic kits and completed figures.
Awesome James! Beautiful work.
best regards
Has liked: 123 times
Been liked: 754 times
James,
Fantastic work on the Tiger. Mind boggling details. The figures look great and very real. Thanks for posting the photos.
William Bath
Been liked: 3 times
Post by William Bath »
Very inspiring James, you set the bar high
William
Has liked: 1023 times
Been liked: 2093 times
James
Thanks for posting - as I said at the Open Day, your Tiger is right up there amongst the best Armortek models. The craftsmanship is exquisite. Two observations - the men in black will be on a charge for leaving a spanner in the engine compartment. Seondly, it's great to see the crewmen with only head and shoulders above the turret line. It's so unrealistic to see these figures standing waist up in the turret on some models. Fear provides the perfect incentive to use the armour for its correct purpose, ie protection. In most armies, with one or two notable exceptions, showing more than head and shoulders would attract a range of punishments from extra duties to the most extreme - posting to a cavalry regiment........
We live in anticipation of the next masterpiece.
Christian Steinhauer
Been liked: 19 times
Hello,
very nice, I like the idea with the footprints.
Christian
Been liked: 1633 times
on close viewing of the photos posted james the tiger is superb, when its on the floor you miss a lot of the detail, a great job well done, to start and finish at this level is an achievment in itself, regards simon manning.
