NOW OPEN
CLICK HERE FOR MORE DETAILS
Anyone cast anything in rubber?
Sarah Frazer
Been liked: 2 times
Post by Sarah Frazer »
Hi Guys,
I want to make some rubber ends to go on the Steve Winstone/Stephen White bump stops. Has anyone any advice as to what rubber would be suitable for molding these rubber ends?
Many thanks,
Sarah
Christian Steinhauer
Been liked: 19 times
Re: Anyone cast anything in rubber?
Hallo Sarah,
some time ago I made rubbers for the Laufrollen of my sWS. I take GM959/GM959-1 from
Ebalta, it's a two-component polyurethane. I only knew a german distributor for it
http://www.ebalta.de .
I made my molds from aluminium. Here are two pics from the mold and from the result.
When the mold is closed, you have a funnel on the top and a screw downwords in the
middel. I haven't made a pic from the closed mold or attached to the drilling machine.
I put the mold with the middel screw on a drilling machine with slow rpm, then I fill
up the funnel with the polyurethane. The rest was done by gravitation and centrifugal
force. To dry it needs 15 hours at room temperature or you can speed it up with an
oven.
Maybe you can find a dealer in the UK or you can order from Ebalta.
Christian
Sarah Frazer
Been liked: 2 times
Hi Christian,
Lovely work on the tyres, very professional :D
I haven't found your casting rubber, but I have come across a similar product called 'Polytek Poly PT Flex Liquid Casting Rubber'. It comes in different hardnesses and can be dyed as well. Do you think this will be suitable?
regards,
Sarah
Hello Sarah,
it should work, the GM polyurethane has also a hardeness shore of 80-85
And this comrade has used the Polytek Poly PT too,
http://www.murrellsmodels.co.uk/Vehicle ... -tyres.htm
Christian
Sarah Frazer
Been liked: 2 times
Hi Christian,
On your wheel mold, was the lettering cut by a CNC milling machine?
I am also very impressed with the idea of using an electric drill to apply centrifugal force. :D
Many thanks,
Sarah
Steve Lewington
Has liked: 8624 times
Been liked: 285 times
Post by Steve Lewington »
Hi Sarah
Have a look at the link below this is where I get my rubber / fibreglass ect from.
There are different grades of rubber for the various jobs you require it to do.
Give Steve a phone of MB he`s the owner he will be only too happy to give you advice on the best grade (hard or soft)of rubber that would suit your needs.
They are in Northern Ireland and his prices are very good and fast postage as well.
They also have a shop on e-bay.
I hope this is of some help to you and others on the forum.
Kind Regards
http://www.mbfg.co.uk/
There is no time for peace.
No respite.
No forgiveness.
There is only ......WAR.
Yes the lettering was made by CNC.
But one small warning.
My rubber rings aren't tested and I can't say anything about durability yet. As far as I know the Ebalta polyurethane is for concret molding, so I thought it's hard enough for this job. With other "lyquid rubbers" I have no experiences and can only guess.
Christian
