making the Fuse-setter
Forum for discussion relating to the 88mm Flak36
Jeffrey Goff
Has liked: 20 times
Been liked: 737 times
Post by Jeffrey Goff »
I started this weekend, on the fuse-setter, I had seen pictures, and the shape being angular and of modular construction, I thought this would be easy, with a few fiddly bits added, I suppose if I had used alloy block it would have been, but I did not have any, so I fabricated it from mild steel copper and brass, there is still a lot of detail and the dial to go on, have posted some pictures of the work so far
regards
Jeff
Jeffrey Goff
Has liked: 20 times
just some pictures of the fuse setter, i have been making this weekend, this is almost a model in its own right, and I have not even started on the top dial
regards
Jeff
Jeffrey
That is a work of art! Beautiful work.
Jeffrey Goff
Has liked: 20 times
Dail and cover added to the top of the fuse setter, just the clutch lever to be made and fitted to this unit, paint still a bit wet and shiny
regards
Jeff
Alfredo Campanini
Post by Alfredo Campanini »
Hi Jeff,
I am following your beautiful work on the 88; my sincere congratulations.
I have obtained the Fuse setter of mine, from an aluminium block, but your system is like the real one and it is better.
Unfortunately we are so far away: it would be good to see the two guns side by side.
Alfredo
Jeffrey Goff
Has liked: 20 times
Hi Alfredo ,thank, you for your kind words, and yes I would like to see your finished model; the problem I am having making the flak 36, is finding period pictures that show the details that need reproducing on our models, the pictures that Vince has on his site are great, but all have been up-graded to the Flak 37
regards
Jeff
Colin Richards
Has liked: 4 times
Post by Colin Richards »
Great Work Jeff. The finished product looks first class. Its a shame that Alfredo lives so far away as it would be great to see the two models together. From the photos available both are a work of art.
Colin
Jeffrey Goff
Has liked: 20 times
Hi Collin, hows the build going, I have not heard from you lately,
will you be going to the modeling show at the Bath showground on the 12th of April
regards
Jeff
Allan Richards
Been liked: 10 times
Post by Allan Richards »
Jeff,
Great work, there is clearly a lot of detail that can be added to the 88. Are you sure this isn't doubling up as some kind of "What the Butler Saw" machine??
Seriously you halftrack and this beauty will be a sight to see.
Allan Richards
Jeffrey Goff
Has liked: 20 times
Hi Allan, yes it does look like a fairground machine, but if it were, it would be playing waltzing Matilda's out of North Africa :lol:
regards
Jeff
Jeffrey Goff
Has liked: 20 times
Now that I know how the light indicators work, I will go back and re-make the elevation and traverse dials.
regards
Jeff
Allan Richards
Jeff,
Are these light indicators going to work?? If so this is a truely amazing model.
Allan Richards
Jeffrey Goff
Has liked: 20 times
Hi Allan, each of the indicators would have had 30, 10v bulbs arranged in three circles, for 100s, 10s and single metres, and by covering each of the lit bulbs, it set the range and fuse setter, what I am going to do on each of the indicator dials, is illuminate 3 on each, to show how they work.
regards
Jeff
Jeffrey Goff
Has liked: 20 times
Hi I have altered the indicator dials, and made the spring clips that hold on the covers, lights have been added to all the dials, just the three dial indicator light, hands, for each of the dials, to be made, I have started to simulate the armoured cables, not sure if this is right on the Flak 36, they were used on the 37, but not on the Flak 18.
regards
Jeff
That is so cool!
Nice work Jeff
