Question about wiring
Steen Vøler
Has liked: 62 times
Been liked: 500 times
Post by Steen Vøler »
Hi Tankers
Found this 24v connecter sharing box. I have orderd one with on-off switchs to each output
My thoughts was to connect this box to the main powersource, the 24 battery, and on the box then connect like this
Armortek mail + & - to one outlet
CTEK 24v charger to second outlet
24v to 12v converter to third outlet
Idea is to have a possibility to completely disconnect the armortek electronics when having maintenence and transportation as well when charging
So I would need to switch on the outlet 1 with the armortek attached here to be able to power on the panzer
Again switch it of and for charging the batteries then switch on the 2. outlet
What do you think - is that doable
cheers
Steen
cheers
Steen
Christoffer Ahlfors
Has liked: 746 times
Been liked: 359 times
Re: Question about wiring
Post by Christoffer Ahlfors »
Sounds like the right thing to do. I do something similar with a power relay (DPDT) that is energized by the charger, routing the charging power to the batteries and cutting the electronics out. It's pretty fool proof. If the charger is attached, the batteries will be charged. There are no settings that can be forgotten in the wrong position.
/Chris
