Hi all
I am in the process of installing a 12v smoker into my JagdPanther
Have a question related where is it best to pull power for the converter
A: directly from the batteries and the have a seperate on/off for the converter
B: From the Armortek 24V loom via a spare connecter
C: From a wiring from a drivemotor
Any advice here is appreciated
cheers
Steen
NOW OPEN
CLICK HERE FOR MORE DETAILS
NOW OPEN
24v to 12 v converter
- Steen Vøler
- Has liked: 62 times
- Been liked: 499 times
- Has liked: 1424 times
- Been liked: 1604 times
Re: 24v to 12 v converter
Unless I've misunderstood, this option:
means it will only work when the tank is moving... ?
Either A or B would be suitable and, if you go with A, you can run the tank with the smoker switched off, hence saving battery power and risking filling cars or rooms with unwanted smoke.
- Been liked: 15 times
Hello Steen
Why don't you fit another battery?
Lee
Lee
If its not broke dont fix it.
Ich Hatt Einen Kameraden
- Steen Vøler
Hi Lee
I have 2 factors going for converter instead of battery.
1 - 12v battery weights more that a converter and I do not want the tank to be heavier
2 - If installing a 12v batteri I also need to have a seperate 12v charger which I do want to avoid
The converter can be bought for appx 25 £ which is a cheaper alternative than a 12v battery and charger + it allows me to use existing 24 CTEK charger
Hi Adrian
Thanks for your feedback. I will connect the converter with a on-off switch to the main batteries
cheers
Steen
Hi Adrian
cheers
Steen
cheers
Steen
Steen
