20 Ton Jack Update (Jacks are Finished)
Posted: Sun Apr 07, 2013 1:19 am
Hi Guys
It has been around 20 months since I first showed the prototypes of my 20 ton jacks, I never expected it to take this long, but finally I have them almost ready to ship. I have made up enough jacks to fill orders plus a few extras for those that would like to order them. See list below of those available ready to ship.
Please note that functional jacks are not designed to actually lift, by cranking the handle the base plate will extend from the jack body. Trying to use it to lift will likely result in damage to the gearing.
Due to the complex cleaning ,alignment of the body parts and fitting of the gears to ensure they work I have fitted all functional kits with working gears. I am offer the functional jacks with gears fitted at the current prices until May 1st, 2013. At this time the prices will be increased by about 15% to compensate me for the additional time involved to assemble them.
20 Ton Jacks fully assembled.
20 Ton Jacks in Kit form.
20 Ton Long and Short Jacks
Tiger 1 and 2 20 Ton Long Jacks
Panther 20 Ton Short Jacks
20 Ton Long Jack Resin and Metal Castings
Tiger 1 20 Ton Long Jack and Mounts Fitted
Tiger 2 20 Ton Long Jack and Mounts Fitted
Sturmtiger 1 20 Ton Long Jack and Mounts Fitted
Panther 20 Ton Short Jack and Mounts Fitted
Here is a list of assembled jacks I have available. For those wanting kits most parts will have to be cast so delivery may take a few weeks.
2 x TT49-01F Tiger 1 20 Ton Long Jack Functional w/working brackets and clamp Assembled $350.00 Each
2 x TT49-02F Tiger 2 20 Ton Long Jack Functional w/working brackets Assembled $320.00 Each
3 x Pan20-02VF Panther 20 Ton Short Jack Functional w/vertical working brackets Assembled $340.00 Each
Here is the current prices for jack in kit form. Price increase will only effect the functional jack kits.
TT49-01F-K Tiger 1 & ST Late 20 Ton Long Jack Functional w/working brackets and clamp as a kit $195.00
TT49-01S-K Tiger 1 & ST Late 20 Ton Long Jack Static w/working brackets and clamp as a kit $150.00
TT49-01R-K Tiger 1 & ST Late 20 Ton Long Jack Resin cast body w/working brackets and clamp as a kit $85.00
TT49-02F-K Tiger 2 20 Ton Long Jack Functional w/working brackets as a kit $185.00
TT49-02S-K Tiger 2 20 Ton Long Jack Static w/working brackets as a kit $140.00
TT49-02R-K Tiger 2 20 Ton Long Jack Resin cast body w/working brackets as a kit $80.00
TT49-03F-K Sturmtiger Early 20 Ton Long Jack Functional w/working brackets as a kit $185.00
TT49-03S-K Sturmtiger Early 20 Ton Long Jack Static w/working brackets as a kit $140.00
TT49-03R-K Sturmtiger Early 20 Ton Long Jack Resin cast body w/working brackets as a kit $80.00
Pan20-02VF-K Panther 20 Ton Short Jack Functional w/vertical working brackets as a kit $180.00
Pan20-02VS-K Panther 20 Ton Short Jack Static w/vertical working brackets as a kit $140.00
Pan20-02VR-K Panther 20 Ton Short Jack Resin cast body w/vertical working brackets as a kit $95.00
Mike
Mike
