OPEN ON THE 6TH FEB 2025
KT Gun Tube Recoil Distance?
Mark Bennett
Post by Mark Bennett »
Anyone know how much the gun tube recoils? I'm constructing the gun tube assembly to recoil on my 2009 KT, but can't come up with an accurate guess.
Has liked: 1419 times
Been liked: 1594 times
Re: KT Gun Tube Recoil Distance?
I don't know about the KT but the Tiger 1 88mm recoil distance works out at 93mm, so that should give you a starting point for the KT.
Christian Steinhauer
Been liked: 19 times
Hello Mark,
in Waffen Revue 110 about the KwK43L/71 is mentioned that the recoil way is
minimum 380mm and maximum is 580mm.
Christian
Mark Bennett
Thanks Adrian & Christian.
That helps a lot since I was underestimating the travel.
