M2.5 hex head steel bolts & nuts
- Been liked: 1 time
I AM HAVING NO LUCK AT ALL IN PURCHASING M2.5 HEX HEAD METRIC STEEL BOLTS X 16MM. I HAVE TRIED EVERY SOURCE I KNOW OF INCLUDING KNUPFER-GROSSBHAN. RECEIVED NO ANSWERE FROM KNUPFER.....PERHAPS I DID NOT DO IT RIGHT. ANYWAY I WILL CERTAINLY APPRECIATE ANY HELP I CAN GET TO TRACK THESE LITTLE PUPPIES DOWN ! MY GRATITUDE TO ONE AND ALL WHO POSTS THEIR WORK ON THE FORUM. ED EARP, JR.
- Been liked: 21 times
Re: M2.5 hex head steel bolts & nuts
How you like these?? The onkly thing is you must buy 100ea. and they are Stainless steel!There are a few sources around but you have to buy a 1000! Martin
http://www.ebay.de/itm/100-Stk-DIN-933- ... 1e74620910
- Been liked: 3667 times
Hi all
Be very careful of using A2 stainless steel fasteners like these. They are very low tensile strength and can not be used for any load bearing task. OK for decorative and detail parts. Never use on gear cases, they will fail.
- Been liked: 13 times
Hi Edvard
You could try my supplier of nut`s& bolt`s.
It is MVD Modellbauschrauben. They have 2,5mm x 15mm steel. They have high head (for steam engine) and low head who is the one`s I use on my build.
adress:www.modellbauschrauben.de At the top right you will find a small vindow with
"sprache" scroll down and choose english, and off you go.
I hope this is what you are looking for.
Ragnar.
PS. all bolts on my Tiger I build with hex head are from this supplier
Ragnar.
THANKS FOR THE TIGER`S
2010 mid-Tiger Nr.005
hello Edward,
here in the uk there is a company called EKP supplies web site www.ekpsupplies.co.uk,
they sell steel BA sized bolts which I think the size you want is 7ba x 3/4, they make 2 different size heads as well standard or a size smaller head sometimes better for us modellers, have a look on there web site and see what's best for you, there not cheap at around £12 for 100 plus postage and don't forget you will need the nuts to suit, if you want to go with this company and they wont post outside the uk let me know and we can sort something out.
hope this helps, Chris.
- Has liked: 13 times
- Been liked: 4 times
http://www.microfasteners.com/
I bought from them, they are imperial but the price is half compared to europe's
Tiki
Tiki
- Has liked: 5 times
- Been liked: 734 times
I am away from home for a couple of weeks but have a good supply of the ekp standard 7ba hex heads.
What do you need them for? I also have some hex heads from micro fasteners, US based. Might be able to give a size comparison.
- Has liked: 10 times
- Been liked: 217 times
Try www.pts-uk.com as they do a huge range of stainless fasteners including split pins, hex bolts etc. I have used them for a while and they are a good supplier.
Mick
Mick
