Hello Tony
Could you please post some pics of the windscreen armour supports and brackets plus measure the post diameter?
Thank you
Hi David, no problem.
This is the base of the rod support in the closed position.
Open position for folding support rods and armour down.
This is the top of the rod. There is a small hole in the armour which the rod sits into, the circular plate on the rod helps give support.
The middle rod has a keeper held in place by a wing nut.
The support rod is 1/2" (12mm) diameter, the foot 1" wide and the circular plate 1 1/4" diameter.
Note that the keeper on the rod base on the drivers side faces away from the other two. That dust gets everwhere, where's me windolene?
If you need any more info just shout!
Windscreen armour supports
I'll be more than happy to David, but isn't Dave Dibb doing these???
If you still want me to measure up and take pics let me know, its no problem.
David,
Have sent you a PM.
Will try to measure up the hood catches for you this weekend.
Have sent you a PM.
