Smoke unit on 222
Posted: Fri Mar 07, 2008 1:29 pm
Hi guys,
Has anyone of you installed the smoke unit on your 222 ?
I have been fiddling around to get the black flexible smoke pipes fitted onto the external exhaust pipes.
I have tried the "hot water" method and even a gasflame to soften the plastic pipes, but they simply won't fit on. And then of course remains the problem of fitting these two within the exhaust cowl at an almost 90 degrees angle.
Any comments will be most welcome.
