John's 2nd Late Tiger 1 2007 release
- Has liked: 5 times
- Been liked: 672 times
I recently picked up another Late Tiger. It was built but in need of some TLC. Sorry I did'nt get pictures of before but could'nt wait to dismantle and strip old paint off.
It's a 2007 release. Here are some pictures of progress.
I would like to build this as a command vehicle but trying to keep build costs down. I will have a go at the antennas but might fit the storage tube.
- Been liked: 223 times
Re: John's 2nd Late Tiger 1 2007 release
Hi John
Shame you didnt get the before pictours,but you are making it look
a new build already
a new build already
Think lots of Gloss enamel. Domestic paint applied with a brush. Luckily not fully painted. Nitro moors would'nt strip it so i TORCHED IT. Eventually everything came up like new. No wear at all. Looks like tracks never touched the ground and electrics as new. It was a bargain.
Here is a better picture of the new floor. Allows easier layout of electrics. Also I intend to add some forward detail to my tigers such as gearbox housing and radio equipment so I need a forward floor. Also started cutting my revised alloy deck support which I hope to detail further soon.
Made another floor for tiger 212 also.
your normal superb build john. One thing i would like to point out in my experience: i have just had the false floor removed from my KT due to the huge logistics in getting at the torsion bars. i.e you have to remove everything just to make a small augustment on one torsion bar.
many thanks
bob
many thanks
bob
Hi Bob, if you look closely at the fitted floor you can see holes wich allow access to the grub screws. Anyway I have very little time to actually drive the tanks so do not adjust too often. Slso the new roof supports are easily removeable to allow easy access.
Front hull supports in aluminium and brass.
Last edited by John Fitzsimons on Fri Oct 25, 2013 7:01 am, edited 3 times in total.
Not a lot of text in last post. Sorry.
I was thinking about making a new turret bin from brass but will use the kit bin for now. Rivets added and main bin assembled. I need to make some new bin lids.
Armorpax track hangers. 2007 kit had no aftermarket parts.
The kit hatches were replaced with armorpax Radio operator and driver hatches. Nicely detailed parts. I have done some work on these to make the locks functional. Also replaced a few of the parts to strengthen.
Last edited by John Fitzsimons on Mon Oct 28, 2013 9:04 am, edited 1 time in total.
Nice work you´ve done there!
I added a set of detailed bumpstops available from Steve Winstone. Very nice work Steve. Sprocket wheel fitted also.
- Been liked: 1643 times
