OPEN ON THE 6TH FEB 2025
Recoiled KWK 43 L/71 gun barrel modified
Chang
Has liked: 16034 times
Been liked: 452 times
Post by Chang »
Hi chaps,
I have seen a brief CAD drawing from a friend of mine the King Tiger's KWK 43 L/71 gun barrel, that the stock one (on the bottom) maybe a little shorter than the real one (on the top):
Is there any possibility from the craftman's market these two extra length parts could be released? Maybe include a longer gun tube(CK0759) too?
Lerh Chang
Fredrik Jorgensen
Been liked: 1 time
Re: KWK 43 L/71 gun barrel
Post by Fredrik Jorgensen »
At 6.24 m the barrel of the KwK 43 was over 1.3 meters longer than that of the 8.8 cm KwK L/56 used for the Tiger I. Also on the drawing you see the later muzzlebreak wich is slimmer and a tad longer. At first they were manufactured with monobloc barrels, but due to the much higher muzzle velocity and operating pressures, barrel wear was an issue. As a result the design was later changed to that of a two-piece barrel. This had no effect on performance but made replacing a worn out barrel much faster and easier than before.
So the notch you have marked is probably correct but as i said i have to look at it.
Have had a plan of doing a new barrel myself
Hmm i need to check this out as well.
Be back when ive checked it
Fredrik
Chang
Post by Chang »
Hi all,
This is the modified 1/6 KT Kwk43 L/71 gun accomplished by my friend Wayne on his KT , with scaled gun barrel length, gun recoiled mechanisms and muzzle flashlight:
A great job done! :shock:
Lerh Chang
Per Sonnervik
Been liked: 1 time
Re: Recoiled KWK 43 L/71 gun barrel modified
Post by Per Sonnervik »
Hi Chang,
Many thanks for the links, lovely work by your friend Wayne.
Would it be possible to persuade Wayne to tell us a little more of his recoil system - that would be very interesting.
Per
Chang
Post by Chang »
Hi Per,
Thanks for the compliments. I will let Wayne know firstly.
As far as I know, it's a customer modifications by himself with his genius. :idea:
Lerh Chang
Bob Gould
Been liked: 31 times
Post by Bob Gould »
Thanks for the link. Love the recoil.. There is so much talent about. :D
