Bonding Tyres to Hubs
Posted: Fri Aug 10, 2012 5:40 pm
Not sure if this has been mentioned before but I've had some good advice from Loctite's technical department on the best agent to bond our tyres to the aluminium hubs. The answer they gave is Loctite 480, here:
http://www.loctite.co.uk/cps/rde/xchg/h ... 000000IRND
It's a type of cyanoacrylate optimised for bonding rubbers and metals to each other. I've now got some from RS Supplies and it certainly seems to do the job. I've used it to bond some tyres which I had to join for the new idlers on my Comet and the bond seems to be very strong. We'll see.
Loctite did suggest the use of one of their primers, depending on the actual material used. It would be very helpful if Mark or someone could pin down exactly the material used in our tyres to confirm whether a primer is needed. I've used it without and it seems fine.
Hope this is useful for those of us still building kits with tyres and especially all those of us waiting patiently for the Centurions to arrive.
All the best
All the best
