machine gun mount
David Gray
Been liked: 1 time
machine gun mount
Post by David Gray »
Has anyone else had the problem where the ball dosent fit into the glacier
it looks like it needs a 5mm spacer
Dave :(
Dennis Jones
Has liked: 10 times
Been liked: 224 times
Re: machine gun mount
Post by Dennis Jones »
Hi Dave,
I had the same problem when I built mine and had to return the glacis plate back to Mark at Armortek for him to re-machine it. Don't use a spacer as it won't look right, I think there might have been a problem with the machining and it wasn't done deep enough.
David Gray
Been liked: 1 time
hi Dennis ,yes your right the recess hasnt been machined deep enough
unfortunatly i cannot send mine back without disturbing the work i have done
so i will try using a large csk bit .
Dave :D
David Tannen
Been liked: 1 time
Post by David Tannen »
hi Dennis
I made a spacer and it worked fine check out my build.
David Tannen
Dennis Jones
Has liked: 10 times
Hi David,
Yes I remember your build now, I helped on the speaker clearance for the gun elevation motor. You don't notice the difference on the m/c gun mount.
Dennis Jones
Has liked: 10 times
Hi David (Gray),
Have a look at David Tannen's build photos page 1 April 20th 2010 and see what it looks like with a spacer.
David Gray
Been liked: 1 time
hi Dennis the spacer looks good , i see Stephen White has also used a spacer
Dave :D
ATTILA KISS
Has liked: 13 times
Been liked: 4 times
Post by ATTILA KISS »
Hi, i just machined a bigger socket..
Attila
