settling suspension
Posted: Fri Feb 01, 2008 2:02 pm
I'v had my Tiger running for a couple of weeks now and have spent some time adjusting the track tension and filing the edges of the drive sprockets to prevent throwing a track whilst driving over some faily challenging terrain (300 tons of spoil from ground work being done around my house).
She is now running really well and performs very impressively as long as, just like the real thing, its carefully driven over tricky bits with minumum neutral turns on slopes etc.
However the suspension has settled bringing the tank hull lower to the ground and sometimes if driving over a narrow object, branch etc, the tracks will ground into the underside of the pannier with a realistic but disturbing grinding noise. Over undulating ground its fine. So, does anyone know what the distance should be from the top of a central roadwheel to the underside of the pannier when the Tiger is on the ground? If I discover the suspension needs to adjusted has anyone found a way of doing this in situ without removing all the roadwheels and the hundreds of ****** bolts!
